91 mustang not starting!
easybake323
Have a 91 5.0, it has spark , has fuel pressure , will start with some starting fluid. But will not stay running or start without starting fluid. Its seems like its not getting fuel?? I am new to mustangs so what should I check next??
Ponyprez
Sounds like a fuel pump issue, buy or borrow a fuel pressure gauge and check the pressure at the fuel rail Schrader valve (Looks like a tire valve stem) which on my 90 is just behind the alternator. Be careful as gas can easily ignite from any spark or heat source. Seldom is a clogged fuel filter the problem but if its never been changed, its a good place to start. it will allow pressure to build but will not let it flow enough to run the engine. The pump is in the tank and is time consuming but with even a cheap repair manual is doable, once again, keep in mind flammability and that gas weighs about 7 pound per gallon so if your tank is full, it's going to be heavy. Please keep all safety factors in mind like use proper jack stands on a level surface.
easybake323
I have a permanent inline fuel pressure gauge and it is saying 40psi when it is on.
Ponyprez
In which part of the fuel line is your indash gauge tapped into, is it before or after your fuel pressure regulator and is the vacuum line secure and dry or wet?
