84 Mustang 302 carb setup, the issue Im having is with the MSD box, when I received the car the gentleman used a spaded connector and plugged the red Ignition wire from the box to some round connector on the drivers side which worked but easily would fall out so I hooked it up to an aftermarket fusebox that is run from the Ignition side, everything I hooked up to it works but the box, as soon as I hook it up there is no spark, not enough power to the fuse box?
