89lx5.0
Yes the oil had some milky color on the dip stick and the rest of the oil
Yes I always add rtv to the water ports.Oh yea also I've heard its a good idea to use a thin layer of rtv rite around the water ports on the intake gaskets. Is this a good idea or just leave it be?
Oh I forgot about that. I have some threaded Rod that I use, just put two of them in. Wooden dowel rod works good tooYea good idea. I also had a idea of taking old intake bolts and cutting the heads of to slide the intake in the studs
Stock gaskets are fine. Yes sometimes the hooks need to be cut off. They only ever really fit oem head gaskets. That's what the Indian head glue stuff is for.Do I have to buy gt40 lower intake gaskets or just 5.0 gaskets? Also the hooks on the intake gasket that hook to the head gasket do they sometimes need to be trimmed to fit? Cause the unused regular 5.0 intake gaskets don't hook they are too wide
Only the upper to lower intake gasket is different for a gt40 intake. The cylinder head side is the sameOk cool. I had a new set of stock 5.0 gaskets and I test fitted them and the hooks would need to be trimmed back half inch. Is there a difference in ho and gt40 intake gaskets?
