you lost me there, if you leave the valve open and on the bottom, wouldnt any coolsnt run right out?
no its no different then the recirculating can that has an open valve on each end, besides the bottom of my catch can is lower than rad overflow port under rad cap. You need and open line at both sides from bottom of can to overflow line by rad cap so after you shut car off the coolant cools down and gets drawn from catch can back up line then into rad, my concern was would it work with mine being a non recirculating can but switching the lines then leaving bottom valve open worked great.
