Erkenbrand
I don't know - I'll ask him.Is the donor car a hatchback? I need a 79 through 82 hatchback latch assembly.
ThanksI don't know - I'll ask him.
I don't have any experience with the gas tank, other than ordering two different ones from Rock Auto and having neither fit (my fault, mostly), so I'll be curious to see how your install goes because that's something I may consider doing as well.I'm about to order the new fuel tank and related parts. I'm getting the 83-97 tank from LMR. The extra capacity will be pretty handy. Anybody have experience with this? I'm guessing it's going to be a bit of a squeeze, but I'm not sure how much massaging it will take to fit where the small tank is now.
Thanks!I’ve replaced mine twice. Both times I bought from O’Riles auto parts. Got all the gaskets, tank level kit and lines from them. No problems.
Thanks for the advice. I'll probably dig out some longer bolts to fit the soon to be too short straps.I have a 83-93 tank sitting on a shelf waiting to go in a 79 Cobra. I got it from Rockauto. It is painted grey and looks like a really nice piece. There are a couple minor dents in it, but you won't even see them when it's mounted (and I mean very minor). This is my 2nd time ordering a tank from Rockauto. The first time, a few years back, it came in comically destroyed. I sent it back and it wasn't too bad to deal with, but I ended up buying one at a local parts store.
As for fitment in the earlier cars, it's my understanding that it will fit with very little modification. You can use your factory straps, although they won't fit into the "grooves" stamped in the new tank, where they're supposed to go. This also means the straps will be too short. You can lengthen them near the rear, in the section that turns up and attaches to the bolts/studs (by the rear bumper area) OR you can just get some longer bolts and washers to reach the (now too short) straps.
I plan to use an in-tank electric pump and modified fuel lines to feed a carb. I'll use a return fuel line and simple bypass-style regulator. Or, a slight variation in fuel line setup will eliminate the need for the bypass regulator. I'll just build the "bypass" into the fuel line and then run an offshoot line over to the carb with a regulator there. There's no need for a fancy regulator that costs $3-500. Just refer to the K.I.S.S. method lol!
