I have a distributor for a 302. I'm needing one for a 351w, so no use for this one. This is the carb distributor, not the type with the tfi module. It originally came with the iron gear, but I just installed a brand new steel gear, so it will work with a hydraulic roller cam. Distributor hasn't been run or installed since I put the new gear on. It also has a new cap and rotor, which has less than an hr run time on it. These distributors are $300 new. I'll take $150 for this one (literally just spent $80 on the new gear and $40 on cap and rotor, both MSD brand). I'll also trade for the 351w distributor, a couple 5-lug draglites (15x7 or 15x8), a set of 5-lug axles, or a 351w oil pan or headers for fox body. Barboursville West Virginia. ![1511 1511](http://www.foxbodymustangs.org/community/data/attachments/1/1512-547ebf7b834e9d4c7b42947803cca8a4.jpg)
