Well, I'm seeing the same measurement on mine. Looks like it would work. Any idea how hard it will be to find a set?
Red,The Cobra center caps have "holes" that go over the studs/lugs.
Not sure if you knew anyone around that had one you could try out.
If you'd like, I'll measure one of mine and get the diameter.
If they are the same diameter I'd even loan you one to try for fit if you wanted.
17x9, which is perfectly fine with me. Any traction needed on the track will be courtesy of a set of draglites and Hoosier bias ply slicks. The staggered wheels do look good, but I like the idea of being able to rotate them front to rear.Nice!
What size are they? 17x9 ? Or staggered widths?
I moved it from the yard to the garage .It can be anything, from installing a turbo kit to washing your foxbody...please do share...what did YOU do your foxbody today?
I'll start, I finally got my ford motorsport decals on my foxbody coupes. View attachment 184
Sent from my HTC EVO 3D.
What wheels and are you using a fox 8.8?Today, well yesterday I upgraded front struts to
KYB AGX .
Also upgraded to 11" 5-Lug Rotors
Next will be 8.8 rear install...
Hope to drive to HOT AGUEST NIGHTS in Reno....
What year and model fox is it, Thunderstruck? Were you able to get the brakes lines all hooked up too?Today I changed out the 7.5 rear-end to 8.8 w/3:55 and 5-lug Yukon axels.
Ed
