So....what did you do to your foxbody today?
Agreed. I was sucked in by the maketing ploy on how these were the next best thing since canned beer. I spluged for a set on the new 88 T-bird Turbo coupe to see if there was a difference. After a month of driving around town it started an awful miss, thought it was electrical, turned out two of the white ceramic resistor tops of the plugs were split down the center, (yes they were checked and gapped correctly before installing). Coaxed the car home and put in the Motorcraft plugs I always use, and all was well again with never another issue. It was a fun day, Driving home with my 2 Cyl. Turbo coupe. Dang, I could have had a good dinner for what I paid for the 4 Bosch plugs. :mad:
Beeker
I do this to my plugs and I find it works good.
Bluez88
I installed my new Pacesetter Xpipe today and noticed something while I was under the car. While looking up I saw the my shifter used 6 bolts, rather than the 4 used on a standard T5. After taking a look at the side of the trans, I found a buck tag that said TREMEC 3550. Needless to say, I was Stoked about finding that out. :)
What a find! I'd like to have a surprise like that underneath my next fox purchase. Way to go.
Bluez88
Picked up some SN95 seats from Phil(Calypso Coupe) this morning and already got them in. I installed my Hurst shift handle over the weekend but kept having issues with the cheap rubber boot they include with it. So me being me, I had to find another way to make it work. I ended up getting the stock leather boot to work with a little finessing. :)
madspeed
gonna have to bring home the steam and hot water power washer to remove the undercoating sprayed allbover the bay by previous owner
Looks good. I had that same shifter before, the boot is cheap for sure. I like how you made the factory boot work.
Bluez88
Thanks. The Hurst boot was way too restrictive too. Always felt like it was gonna pop the car out of gear because of the hard rubber material that was used. No issues with the leather boot though. :)
BANDITGT
Starting to finish up my heated core install. Hope to finish by tomorrow evening
Sent from my drivers seat on my iPhone5 via Tapatalk
BANDITGT
Drove it to work for the first time in a few months. Heads, cam , heater core, motor mounts, caster camber plates, electric fan , etc... Later.
Bluez88
Broke my hand on Sunday(Which was also my birthday, Go Figure haha), so I haven't been able to return to work. Can't do a whole lot being that it's my right hand so i did the easiest thing possible and washed the car. Haha20130205_160438.jpg
89lxfox
Put a new harmonic balancer on my car today the rubber was coming out of the old one and causing some vibration then set the timing to 14* was 16* just a little bit high
