John2002
"MF" yep, its a good thing....LOL I padded my MF this weekend too ,the lady at the end of my block paid in full for grass cutting season...cash money ....BEST KIND...
Idle is too low. Turn the idle up to 800-850 in park warmed up. Then re adjust the TPS and throttle valve cable. The right way to adjust is with a pressure gauge. It should read 0-5 psi at idle, and climb with the throttle. The easier but less accurate way is to pop the lock up on the plastic rod, and with the throttle at idle there should be no tension either direction on the cable. I have found my car likes a small amount of tension at idle and shifts perfect. If anything you want a little too much TV pressure (I.e tension on the cable) a lack of pressure can and will grenade the tranny in no time.TVAOD.....yep, that code for Throttle Valve Auto Over Drive...yeah, but what does it mean????I can't get back into first gear without touching the brake , It will idle at 10 to 12 miles an hour in second gear. I wet to YT and watched and read a few too many How To's .It idles at 625-650 in park when the engine is warmed up , in gear with the brake on its about 600. Other then that it runs fine... I did that measure once slide twice deal on that clevis thing but I haven't gotten the car out yet for the test drive as of yet..Any Clue???
