Looks great! I need to do the same to the draglites on my pace car. I also picked up another set of draglites in 5-lug. They're in dire need of a good cleaning and polishing. I plan on doing a 5-lug conversion to one or two cars this summer.
Change radiator to 3 core mishimoto new water pump and thermo housing thinking about going back to mechanical on my fans any thoughts?
I 2nd this. I will never run a clutch fan again. You have to upgrade you're alternator, of course. But then again, I'll never run the stock alternators in these cars again either! A 3g swap is easy and cheap. Plus, it eliminates a known fire hazard with the 2g set-up. The two upgrades go hand-in-hand imo.Are you already running electric fans? If so, why switch back?
I prefer my electric fan; not only because of the HP it frees up, but the front of the engine looks cleaner.
Do you plan to add a supercharger or turbo to the car in the future? If you do, then you'll probably will need the electric fan.
Well wanna eventually run electric fans just not enough experience with running electricelectrical and don't wanna screw up shroud fans with 3 core I hope should keep me kool got no mechanically inclined friends so got no help other than u guys here so thanks for any and everything I really appreciate it guys worked my butt off for my first stang at 16 and lost it to a thief now I'm 43 and got aanother 1 so eager to keep it RollinAre you already running electric fans? If so, why switch back?
Not planing on it but will the shroud and clutch fit with blades with 3 core?Are you already running electric fans? If so, why switch back?
Who could drive such an ugly pile? Lol
I finished some work on the rear suspension and brakes. I've only had time here and there to work on it. Just too much going on, I guess.
I'm usually the type that researches everything before jumping in. I overlooked a big one here. The plan was to have a set of 5-lug wheels with street tires and keep bias ply slicks on my 5-lug draglites. I ordered a set of 3" wheel studs for the track. I'm doing the 94-95 sn95 spindles up front, which takes care of the center cap issue. It never dawned on me that I would have a similar issue with the rear axles, using the long studs.
At this point, I can cut the studs down, run the wheels without centers, or get me an extra pair of draglites for street tires.
I really had my heart set on these factory wheels, but draglites make more sense I guess. I hate these decisions.
They look like they're a good 3/4" too long. I don't think they'd look right even if a deeper center cap did fit. I will most likely just use these wheels on the cobra and find another set. I actually have another set, but I'm not crazy about them. I'll figure something out lolHave you tried fitting the center cap? How much did it lack clearing?
I wonder if a pair of 94-97 Cobra center caps will fit those wheels?!
If not what about just marking the back side of the center cap and drilling a clearance hole at the studs?
